Hi all,
Trying to remove the main fairings but each time get to a point where I feel something is going to break. Each fairing has two bolts and 4 + 2 poppers that need to be removed. After this it should just pull off. The problem is that the fairing seams also to be attached to the tank cover and this is what causing the problem . When I pull the fairing at the top it is attached to the tank cover.
Any ideas?
Thanks Spanish
Any ideas?
Thanks Spanish
