1 - 20 of 20 Posts
I’m ultra cautious about looking after the wheels, only use a chain through with a double protection sleeve etc, however, I’ve noticed 3 or 4 areas on my rear black wheel, where there is paint flaking/ metal exposed. Not huge areas, but annoying. The paint must be ultra fragile. Not long bought it, and just wondered if it is a thing on the AT?
cheers & stay safe.
Should post a couple of pics to show.
It appears Honda uses enamels on their sportier bike rims that is extremely durable to onroad/storage/weather elements, but maybe it cannot take rocks that the AT would otherwise routinely experience offroad. But it sounds like the current method is vulnerable too.
54632
54634
I agree. Just whacked some black nail varnish on to try to seal the small area’. Not mine incidentally 😬
Dave: So to understand correctly, these "chips" were caused by storage or on/offroad use?
Not sure really. No long owned the bike, so may have been there when I got it. Never noticed them though. I suspect it’s a chain? I haven’t really used it with the lockdown here. I’ve had an Abus chain in a plastic case, in an Abus nylon sleeve, very gently passed through, not dragged. I’m certain it’s nothing I’ve done. I’m not using the chain anymore though, because the paint is obviously vulnerable to damage. Cheers
Looks like stone damage but could be anything hitting it this is what my front looks like, this happens on gravel roads where its quite deep, AT s with the anodized wheels dont mark up as bad. Next time I straighten the front rim I think I will get it black anodized.
54641
Cheers Mate, I’m guessing the aluminium won’t corrode too much/ look too bad. Not like it’s steel & rust. Guess it’s just an occupational hazard and I’ll just need to learn to live with it.
I know its not the easiest thing to do and I am guilty myself tbh...but if you can attach the chain to the frame rather than the wheels.
1 it will save you from this damage
2 harder for scumbags to just take your wheel off and drag the rest to the van.
another thing I'm going to try as my chain cover is wrecked is to sleeve it in an old inner tube in the hope it lasts longer and provides protection....after lockdown of course when we can simply go to the bike shop :(
Discussion Starter · #11 ·
Sounds like a good idea. My chains in a shrink wrapped plastic sleeve, and the nylon sleeve over that. I try to keep it clean. I guess you only need a bit of grit or something, and with the weight of the thing....
This looks like corrosion that is caused from brake dust. If it gets damp it eats through the paint or anodizing and starts to pit the aluminum or plating on the steel.
Just wondering if switching to organic pads would make a difference?
I know from past experience riding on the beach threw salt water has a similar effect. If left for to long. Salted roads or brackish waters maybe.
Once theres a blemish in the finish salt will take over.
Yeah if that's the case, I'm guilty. I liked to keep the dirt on my bike to remind me of the ride. Besides why clean it when its just going to get dirty again? Guess keeping your bike clean is part of good maintenance.
I live in Orange County, CA so not a lot of salt on the roads and I don't hang out at the beach enough with the AT that I think it would be from that.
1 - 20 of 20 Posts
