Do you need to take the gear lever linkage rod and gear levers top and bottom off the bike before getting this cover off? Seems like a massive faff just to be able to clean crud out from behind the cover! Or is there a quick tip way!:wink2:
No. Remove the shoulder bolt from the actual shift lever. You can then just swing the lever and linkage out of the way enough to remove the sprocket cover.
All done! Thank you. This forum always throws up the answer to all conundroms! I love it...
