1 - 2 of 2 Posts
Not a member on ADV, but a poster pointed out the close fit between the axel nut and the fork leg shield. Likely need a socket to remove it. I don't have a 22mm socket but a 7/8 will work. Not a problem here, but someone
without a lot of tools may want to take note.
I have the MotionPro spanner and tire lever it is a push fit to go on the nut but does just fine the the fork leg shield does bend out of the way.
I have changed wheels on three ATs now they all look tite but you can just push the lever onto the nut just fine (the MotionPro at least have very rounded edges on the spanner end)
1 - 2 of 2 Posts
