1 - 9 of 9 Posts
Has anyone installed the GIVI 1179FZ Monokey Rack onto the 2020 AT DCT? The instructions from GIVI are hard to follow, and I cannot find a video on Youtube.
I have the 1179FZ on my bike, I found it very easy to fit, what problem are you having?
Thanks for checking in with me. I was wondering about the drawings in the instructions for removing the plastic side piece. It says to rotate something and remove it. Do you remove a subassembly of the plastic piece to make room for the rack?
Hi, yes there is an infill panel to remove on the back of the panel, you just twist the grey securing clip and it releases it.
63896
There are two push pin clips, gently push the centre until it clicks and remove.
63901
Under the bike is one 5mm hex screw.
63902
Unclip the panel at the front first then at the rear.
Hope this helps.
1 - 9 of 9 Posts
