GPS mount for CRF1100 DCT standard model?
20003 Views 50 Replies 20 Participants Last post by  fatfurious2
I have a Garmin Zumo XT, looking to mount on the AT as a dedicated GPS. Any recommendations on what mount to get in order to mount on top of the TFT? I read the Touratech GPS mount is only for the AT AS model, i have the standard model. Any recommendations are welcome.
1 - 20 of 51 Posts
I don't know how much help I will be, but I bought the Givi GPS / Smartphone Bracket which I have yet to install. However this and the Touratech has been discussed here. Search is always your friend.
Ok
Givi makes them
FB1179 is for standard AT
FB1178 is for ATAS
Link below is for FB1179
Automotive design Motor vehicle Automotive tire Machine Automotive exterior
Hi I have just ordered this new Touratec handlebar mount, but still pending arrival. I trust this will fit
Handlebar mount for Garmin Zumo XT lockable, black
I believe mounting the XT with lockable mount will vibrate and is in line of vision. I personally run the Touratech handlebar mount and lockable cradle on the central bar. Very solid and when riding they line up exactly from the TFT / small screen/Nav. It does protrude out much when riding.
Fuel tank Tire Motor vehicle Vehicle Hood
I believe mounting the XT with lockable mount will vibrate and is in line of vision. I personally run the Touratech handlebar mount and lockable cradle on the central bar. Very solid and when riding they line up exactly from the TFT / small screen/Nav. It does protrude out much when riding. View attachment 68152
Yes, that's the one I have ordered for a 1100 l DCT :)
Looks great and fits in perfectly! How did you wire it?
There is a spare plug available under the cowling.
MatthewH have you mounted a tank bag with the Zumo mounted in this position? Does the tank bag block or approach blocking the GPS screen line of sight? I am considering a Mosko Moto Hood tank bag which is their middle size tank bag.
Thank you
Hot or switched power? Any tips on where this spare is located? How hard to get to it?
Yes hard to find, still searching, is it possible to use the usb contact??
4
Ref USB i dont think so , would i be right in saying the voltage isnt right ? Only reason i say that is that it wouldn’t charge my Garmin when i tried it.
With a Honda Tank Bag there is full visual of the Nav. I believe its 8 L bag. If it were bigger like expanding tank bag it would cover the nav but a non expandable bag would work.
for me having Nav in its current location makes it really easy to data input whilst on the move without having to lean forward.
picture one is my rider view of the Garmin
Cable is switched Power , eg ign off and Garmin Powers down which is located near the heated grips connector th
Tire Automotive tire Motor vehicle Automotive design Vehicle
Tire Wheel Automotive tire Automotive lighting Hood
Computer Computer keyboard Hood Automotive tire Motor vehicle
Motor vehicle Automotive design Automotive tire Bumper Automotive exterior
Reactions: 2
Cable is switched Power , eg ign off and Garmin Powers down which is located near the heated grips connector th View attachment 68176 View attachment 68177 View attachment 68178 View attachment 68179
Thanks Matthew, very good mount and i will surely do the same on mine 1100 dct 2020 not AS, so I hope they have shipped the right stuff
Should be the same as not aware the AS is any different
Reactions: 1
Touratech has the best one IMO. I purchased the one that goes above the TFT screen and is behind the windscreen. The safest one as it is in front and your eyes don’t come off the road I. Front of you. Takes about 20 minutes to install. It has everything the Zumo needs to power up. Need to run a cable to supply power. That takes a little effort to connect correctly.
You might check Camel ADV. They have some good products. Not sure if they have it for your specific year model.
I just cannot stop loving this cockpit view with my touratech mount installed, and wired through the usb connector, works perfectly !😷
Automotive tire Motor vehicle Electronic instrument Gadget Bumper
Reactions: 1
Looking good, all the planets line up!
Have you changed all the screens to Gold menu’s?
Thanks Matthew, yes I have changed 2 gold, but quite frankly I don't use much of the info, but good to see how much fuel left in range :)
My quad is a Can-Am Outlander 650 - Rotax V-twin engine
1 - 20 of 51 Posts
