1 - 2 of 2 Posts
I prefer softer grips than the AT's stock grips, so I replaced them with Pro Grip 714 Dual Sport Grips. They are dimpled, beveled grips that have a greater circumference in the center than at either end. I cut the stock grips off with a razor, being particularly careful with the throttle grip, and cleaned the glue off the clutch-side bar with carb cleaner. I trimmed the grips to fit and installed them using soapy water as a lubricant. The grip with the bigger opening goes on the throttle side. The water dries overnight and the grips don't slip. The pics show the the results.:smile2:
1 - 2 of 2 Posts
