In the process of adding the Camel adv windshield bracket I managed to drop one of the bolts into the headlight assembly. One should also read the written instructions in addition to watching the video. The written instructions warn of this problem. So I have stripped down the all the plastic and the headlight assembly is loose but for disconnecting the connector at the top center of the assembly. But unlike the other connectors I cannot find or see a release tab to allow the connector to be removed. Has anyone removed this connector? Do you pry it off? Any assistance is appreciated. I hate to be stumped by something which is probably simple but hesitate to go any further given I may break an expensive assembly.
Ugh, I had the same thing happen today. I removed the headlight assembly and could hear it rattling around and almost got it out, then it got stuck somewhere. The headlight assembly is $1,500 to replace so I don't have the guts to try to pull it apart.
