1 - 3 of 3 Posts
Help please
I currently have the front end disassembled ready to wire accessories.
The last job is tank removal.
Everything is disconnected except the main fuel line “quick release”
I can’t figure out how to simply remove it. :confused:
The tank removal video on Youtube is of no help as it’s not shown.
(ok I’m dumb :eek:) Any clues please?
Discussion Starter · #2 ·
Panic over
I don't know if I did it the easiest way but I removed the white plastic "lock"
Then with a small screwdriver opened up the two legs that sit in front of the lip, while applying light tension to the pipe.
I was very cautious (overcautious) at first as I didn't want to snap anything. but I raised the tank a lot higher and got a better view.
Phew:smile2:
I am having the same challenge removing the quick disconnect. I lowered the white safety clip but seems to hard to remove.
I will try Ray's technique, I think the two "Legs" he is talking about are the black color sections of QD.
1 - 3 of 3 Posts
