21 - 31 of 31 Posts
Made a simple connection drawing for those who are interested in using the dimmer control. I also used a DIY Soldering PCB to solder the relay / diode with the 3 wire leads. View attachment 67181
I still plan to use Your awesome diagram here, but it's just too cold out in my shop, which is basically a carport, to do this kind of work. Looking forward to some better lights for sure.
CRF1100L Africa Twin Adventure Sports 2021
Not yet. I've yet to buy the lights I'm wanting due to them not being in stock. I might go ahead and wire up my relays however. Then All I'll have to do is mount the lights, and plug em in. I still haven't decided where I'll tap the wires either. I might have to take the side panels off to find the right spot. View attachment 64241
hi, can I have a zoom out copy of this? Also with the green mark removed. Thanks, highly appreciated.
2020 AT DCT
Thoughts?
See the diagram on page one of this thread where I measured both the blue and white wires.
  1. The white wire (H/L LO) on pin 4 of the BCU is 12V all the time when the ignition is switched ON... so high beam switch makes no difference for this wire.
I meant this pin 19, White.
Rectangle Slope Font Parallel Auto part
2020 AT DCT
I meant this pin 19, White. View attachment 68257
That should work. I can’t see the common but assume it’s 12V. Just make sure to use a low draw relay so as not to load down the BCU input and a diode to protect from reverse EMF when the relay deenergizes.
I will be using a single channel electronic relay module for aduino. I would highly appreciate if there is a complete wiring diagram of the BCU showing the end of the control cable.
If I am not mistaken and someone informed me that handle bar controls are COM wires. So there should be no issue about reverse voltage. Only tapping for a signal.
Module description:
1. the module uses genuine quality relay, normally open interfaces Maximum load: AC 250V/10A, DC 30V/10A;
2. using SMD optocoupler isolation, driving ability, stable performance; trigger current 5mA;
3. the module Operating voltage 5V 9V 12V 24V ;
4. the module can be high or low by a jumper setting trigger;
5. fault-tolerant design, even if the control line is broken, the relay will not operate;
6. the power indicator (green), the relay status indicator (red)
7. the interface design of human nature, all interfaces are available through a direct connection terminal leads, very convenient
8. module size: 50mm*26mm*18.5mm (L*W*H)
Module interface:
1. DC+: positive power supply (VCC)
2. DC-: negative power supply (GND)
3. IN: can be high or low level control relay
Relay outputs:
1. NO: normally open relay interface
2. COM: Common Interface Relays
3. NC: normally closed relay interface
High and low level trigger options:
It is low level trigger when jumper connect to LOW pin
It is high level trigger when jumper connect to HIGH pin
interesting … On my 18AS I have no issues with just running a simple standard 12v relay using the high beam as a trigger. it woks fine, but then, I’m using the hot wire to the high beam bulb as the trigger…
21 - 31 of 31 Posts
