1 - 9 of 9 Posts
Heh, maybe more correctly: How much was spent on it.
After seeing what other Forum members have been doing to their machines, and even my own farkles, it is so easy to rush and add/change things to the AT.
My guess is he probably has some professional considerations and spent far less on it than you or I would :)
Have followed his channel for a while. The guy seems to enjoy the bike and uses it to it's fullest.
He says he has no idea of the total cost, since many of the items were donated for "evaluation" purposes.
He did a video where he weighed the bike, with a full tank of gas, no panniers attached, all his normal tools/spare tubes etc attached. It came out just shy of 580 lbs, if my memory is any good. I would have thought more, but maybe the exhaust and Lithium battery cut enough off the weight to make it managable. I would have guessed over 600 lbs, with a full tank.
RW Dyno's at 107 hp with the exhaust and PC V tuned map.
If you figure a 25 hp loss with a shaft drive, then that should be pretty competitive with a BMW GS...
I liked his TPMS; so copied that, this week!
1 - 9 of 9 Posts
