1 - 14 of 14 Posts
· Registered
Early this morning on Facebook, Honda Portugal posted and removed the apparent spec sheet for the CRF1000L Africa Twin
Power: 70 kW (93 horsepower)
Torque: 98 Nm (72 ft-lbs)
Dry Weight: 208 kg STD (458 lbs) 212 kg ABS (467 lbs) 222 kg DCT (489 lbs)
Wet Weight: 228 kg STD (502 lbs) 232 kg ABS (511 lbs) 242 kg DCT (533 lbs)
Fuel Capacity: 18.8 L (5 gal)
Length x Width x Height: 2335 x 875 x 1475 mm (92.7 x 34.4 x 58 in) STD, 2355 x 930 x 1475 mm (92.7 x 36.6 x 58 in) DCT
Wheelbase: 1,575 mm (62 inches)
Seat Height (STD/Relaxed): 870/850 mm (34.2/33.4 in)
Ground Clearance: 250 mm (9.8 in)
Front Tire Size: 90/90-R21
Rear Tire Size: 150/70 R18
· Registered
5 gal tank should be good for about 200-225 miles on a tank...the Honda twins are usually fantastic for fuel economy... maybe even longer if theres an ECO mode... DCT probabaly even better...
Peak power at 7500 RPM, probaably a pretty flat torque curve.. can't wait to see the sheets!!
· Registered
honestly after watching the video and seeing the specs, I'm betting this thing is going to be as close to a 1000cc dual sport as you can get.
Hondas been saying since day one this thing is going to be great in the dirt, I don't think they're lying either...
· Registered
Motorcycle.com translated the rest of the spec sheet http://www.motorcycle.com/manufacturer/honda/2016-honda-africa-twin-specs-leaked-video.html
Engine Type: Cooling by liquid, 4-stroke, 8-valve, two parallel cylinders, crankshaft 270 and Unicam system
Displacement Engine: 998cc
Maximum power: 70 kW (93.9hp) @ 7500 rpm
Maximum torque: 98 N.m (72.3 lb-ft.) @ 6000 rpm
Bore x Stroke: 92.0 x 75.1 mm
Clutch: Wet, multi-disc corn coil springs, camshaft Assistant aluminum and sliding clutch
Final transmission: Chain sealed by O-rings
Type Gearbox / Transmission: 6-speed manual / 6-speed DCT with driving modes for on-road and off-road
HSTC system (Honda Selectable Torque Control): HSTC 3 levels + interrupter switch-off (only versions ABS and DCT, not the STD version)
Frame Type: Frame semi-double cradle steel, with rear sub-frame in high strength steel traction
Turning diameter: 2.5m
Dry weight: 208 kg/458 lb (STD), 212 kg/467 lb (ABS), 222kg/489 lb (DCT)
Curb weight: 228 kg/502 lb (STD), 232 kg/511 lb (ABS), 242kg/534 lb (DCT)
Fuel tank capacity: 18.8 l (5 gallons)
Length x Width x Height: 2,335mm x 875mm x 1,475mm (STD) 2,335mm x 930mm x 1,475mm (ABS / DCT)
Wheelbase: 1,575mm
Seat height (STD / lowered): 870 / 850mm (34.3 inches/33.5 inches)
Ground clearance: 250mm (9.82 inches)
ABS system: ABS 2 channels switch off the rear ABS (ABS and DCT versions only)
Front brakes: Two 310 mm floating discs, radial calipers hub and 4 pistons (ABS) and sintered pads
Rear brakes: A floating disc 256 mm a 2-piston calipers (ABS) and sintered pads. DCT version also includes parking brake system.
Front wheel: wire-spoke with aluminum rim
Rear wheel: wire-spoke with aluminum rim
Front wheel: 21 m / c x MT2.15
Rear wheel: 18 m/c x MT4.00
Front tire: 90/90-R21 with tube
Rear Tire Size: 90/90-R21 with tube
1 - 14 of 14 Posts
