1 - 7 of 7 Posts
That is the official weight limit from Honda's literature. I am 200lb/91kg the girlfrien is "approximately" {She would kill me if i gave the real number) 120lb/54kg. That would leave 64lb/29kg for luggage gear and gas when we go two up camping.
I am not going to carry my whole apartment and I know from backpacking that every ounce/gram counts. But that still seems like a slight amount when you consider the weight of alum luggage itself. And i am definately going with the alum Givi or SW-Motech luggage. I live in a big city and there are some thieving people here. I know nothing is going to stop a thief if he/she is really determined but I want to make it as hard as possible.
Sure about the 174kg?? Here in Germany specifikation is a load of 195kg with full gas tank, for manual and DCT.
dry weight 208 kg (STD) / 212 kg (ABS) / 222 kg (ABS & DCT)
with full tank 228 kg (STD) / 232 kg (ABS) / 242 kg (ABS & DCT)
max weight 423 kg (STD) / 427 kg (ABS) / 437 kg (ABS & DCT)
Max. load 195 kg
My manual (US) says 178kg or 392 lbs. *including rider, passenger, and all accessories.
If you buy the SW Motech, you can also use soft luggage with them which should get you another 20 lbs. or so over the aluminum panniers.
Oh well looks like you'll need to leave something at home :wink2:
Only joking :grin2: but what I think you may need, most people call it suspension improvements.
Simple, if you don't want to damage the bike on a fall, fit crash bars.
If you want to carry more weight fit heavier springs, then you wont have to worry about breaking things, and enjoy your riding. :grin2:
I am nearly 260lbs after all the Christmas cokies and my wife 100lbs. So with luggage I would technicaly need yellow warning lights like a heavy goods transport :D
So far I never had the feeling that there is a issue for the bike with my weight. The only problem I had so far is that even on max preload the rear spring is too soft.
I got that number from an article in Road Runner Magazine. So it might not be the exact figure.
I definitely need hard pannier and top box. I live in and highly urbanized city where I would not put things in soft luggage while riding around town.
1 - 7 of 7 Posts
