Hi everyone.
I seem to have begun noticing a howling sound at speed. I can control it somewhat with changes in throttle or clutch input. It usually happens above 30mph and when I'm cruising. It doesn't seem to be gear dependent and I don't notice it when I'm going really fast or under strong acceleration.
I've checked my chain and tightened it up a little per usual maintenance. The wheel is running true, too. I noticed this sound even before I did my chain clean and maintenance. It has not subsided or changed following the clean and lube. I tightened the rear axle nut to spec.
I don't remember ever hearing it before these last couple rides. In fact, I remember noting how quiet the bike was and how I only hear the whirring of the cam chain. So this is definitely new.
If its howling and I pull in the clutch, it changes its sound. Its becomes less pronounced or quieter. When I let it out, I hear it again.
I don't think it is aerodynamics related. I think this is mechanical. I cannot replicate the sound while free-wheeling on the center stand.
Bike only has 1000 miles on it.
Do any other AT owners notice a howl to when cruising at speed? Could this indicate a wheel bearing about to fail? Wheel spins fine and the sound only happens when going 30+mph or so. I DO have the stock tires... but they seemed fine a few miles ago. Does anyone notice the stock tires howl? I don't have any dirt roads around me to isolate them with.
If its normal, I'll try and ignore it. It seems to be all I can focus on right now, though. Driving me bonkers.
