My guess is front tire wear. My Mefo Explorer tire started howling at 1,000 miles.
Check for cupping on the front tire.
I have a '17 DCT model with the stock front tire and I have noticed it howling lately (3500 miles). Close inspection revealed that it is cupping also. I have already bought a new set of Mitas front and rear but have not installed them yet. I am sure that will quiet down the front tire.My bet would be front tire... The stock Dunlop on my 2017 was getting noisy at about 1200 miles. Not enough to bother me, but definitely noticably louder. I pulled it and put a Shink 705 on front, and it got quiet.
May be something else, but that is my guess.
At 1200 miles I seriously doubt you have a dry spline. If you do lube the spline use Honda Moly Paste. It's like $35 for a 2oz tube but anything else is useless.Upon seeing what Tetsuhiro shared, I think I will remove the drive sprocket and check the spline. Lube with a little grease to be sure its not that. Thank you for the information, Tetsuhiro!
it's the 'Disco' LED lights in the background at the shop, a white LED work light and the iPhone 11Pro.This image "almost" has that 3D look to it.
I think it happens when something is reflected off the blackness of the bearing hole on the computer screen and scrolling the image at the same time.
My stock tires howl since new.My pick will be tires, ditch them they are garbage anyway .....but I really think its the tires
