Hi Guys,
Due to a disability I need to run a separate indicator switch over on the right hand bar. figuring how to mount and getting the feed over i can sort but need a little advise on type of switch needed.
A simple "on off on" will suffice but need an idea on amps/volts etc the switch will need to handle.
I'm guessing 12v is the standard but Amps ???
thanks in advance
Andy
I would just add a switch from Tusk or someone - that is made for replacing old dirt bike switches or making a dirt bike street legal. This one would move your turn signals and horn.
https://www.rockymountainatvmc.com/parts/tusk-compact-control-switch-with-on-off-p
I swapped the left control on my FZ-09 for one from an FZ-07 because reaching across the turn signal to hit the tiny horn button had me alerting drivers of my presence with my blinker... I got a tool from Eastern Beaver that pulls the pins from connectors because the connectors were wired differently. You can get one and a couple of connectors to create an extension over to the other grip.
