Following months of tidbits from Motorcycle publications and general online chatter about the upcoming Africa Twin, a series of solid information has released outlining key information and details we need to know, all in right timing before the initial press launch this October. While you'll find that series of information below, it's not comprehensive but is the most available to date. Around the time of the October launch, expect to see Honda release a wealth of what you need to know.
For now, keep an eye on the forum for the latest news.>>
Specifications
Release Date
Press Launch In October
Price
Pictures
Specifications
_______________________________________Months of teasing and years of speculation have finally come to an end, the Africa Twin lives again.
The CRF1000L is a totally unique machine from the ground up, the 998cc parallel twin is all new, as is the new twin-spar cast aluminium chassis. Changing the game however is Honda's Dual Clutch Transmission, a first for off road motorcycles.
Some have lamented that the new CRF1000L does away with the V-Twin configuration of the original XRV Africa Twins, don't fret, P-Twins offer a far more versatile package. Its easier to cant a parallel twin forward then it is a V, which frees up space above and behind the cylinders.
The engine itself uses lessons learned from the CRF program, a 4 valve Unicam cylinder head helps keep the engine as compact as possible. The single camshaft shares the same lightweight construction with the CBR1000RR Fireblade.
Honda had this to say: "The engine’s short height contributes to the CRF1000L Africa Twin’s excellent ground clearance – another prerequisite for a true adventure machine. It also uses clever packaging of componentry to both dynamic and aesthetic effect. The water pump is housed within the clutch casing, and the water and oil pumps are driven by a shared balancer shaft. Further reducing engine size is the lower crankcase design, which stores the oil and houses the pressure-fed pump.”
Look for the CRF1000L Africa Twin in dealers across Europe by this fall and on North American shores by early 2016. European base model pricing begins at €12,100. Europe will have the choice of HRC Tricolor (white), CRF Rally (red) and Ballistic Black, while North Aericam shoppers will be offered the AT in Silver or CRF Rally (red).
click here for Full Technical Spec List
Release Date
_______________________________________American Honda has confirmed that the all-new CRF1000L Africa Twin will be in U.S. dealers early next year(2016).
_______________________________________The official press launch of the CRF-AT will take place in October. Not sure if we'll need to wait until then for a pricing breakdown... but I did just read that ABS and TC would be standard in the US now...
Price
_______________________________________I looked at three different sites and the prices are the same but it's listed in Australian dollars.
The price in Australian dollars is as follows:
$15,499 for the base model
$16,999 for the ABS model
$17,999 for ABS-DCT model
Here's a bit of conversion from The Ride Advice.
Pictures
