1 - 4 of 4 Posts
I am installing a Eastern Beaver Fuse Box. One of the accessories I am installing is a Givi S310 fog lights. I was wondering if any one knows the best wire under the seat to tap into so my fog light turn on and off with the ignition key. Need color and location of the wire. Halogen not LED, so need 15 not 7.5. Thanks.
If you purchased the Eastern Beaver fuse box that will provide switched power for you. Depending on the model purchased, the 3 fuse block will provide either 2 or 3 switched outlets. Part of the install process for the EB fuse block plugs into a power harness connector under the seat that provides the switched power signal to the relay in the EB fuse block, so you will already have switched power supplies. I suspect the 8 outlet EB fuse box also ties into switched power via a relay in the same manner. If you need any help understanding the install, PM me and we can talk on the phone to clear up anything.
1 - 4 of 4 Posts
