1 - 3 of 3 Posts
Im sure you guys see this alot but heres mine.
Had a piece of 3/4in (ish) aluminium plate lying around so I slapped it on the rear with worm gear tube clamps and got a $30 HF hard case and bolted it to the plate. The pre drilled holes around the outer edge are perfect size for straps.
I tested the mounting by grabbing the plate and lifting it and moving it side to side. It's going no where.
1 - 3 of 3 Posts
