1 - 2 of 2 Posts
HI!
If you are talking about the OEM accessory power outlet (left side inside the fairing) it should/must be connected to the auxillary connector (behind the front mask. By that power is available only when the iginition is on. Even if you are using an aftermarket power outlet I'll highly recommend to use the standard auxillary connector too.
Cheers, gerhard
1 - 2 of 2 Posts
