1 - 6 of 6 Posts
my no plate light appears to be loose if you push light down you can see the bolts
how do i gain access to solve this bolts seem to be well cover inside rear mudguard
Water will not get in. The seal is tight; the rubber mounts for the taillight are loose. Designed that way.
If you want to go nuts, remove the rear seat and rack to access the taillight mount bolts and shim the rubbers. Totally unnecessary. It works. Spend your time riding instead.
1 - 6 of 6 Posts
