OEM Crash Bar Set (Engine & Body) Compatibility
790 Views 3 Replies 3 Participants Last post by  Red
Hi guys,
just a quick question as I could not find the answer with a simple forum search:
are the OEM crash bars for the AT >2020 compatible with the ATAS ES DCT 2021? And also do they come with 2 separate installation kits (one for the body, the other one for the engine)?
Found some decent used ones at a good price and I am not sure if there is going to be a compatibility issue.
I am talking about the whole set: the body protection and the engine guards - both kits are OEM
Thanks in advance!
1 - 4 of 4 Posts
The lower bars seem to have the same part number between models but the upper bars have different part numbers for AT and ATAS.
  • Helpful
Reactions: 3
Because the bulkier tank on the ES requires different crashbar geometry I guess…?
Reactions: 1
Thank you! Its clear then. Upper ones not comaptible.
1 - 4 of 4 Posts
