1 - 2 of 2 Posts
I'm new here. I bought a 2018 Adventure Sports DCT. I added the low seat (2.5"). This is what it should have come with.
I am adding Auxiliary lights and not sure about the wiring using the High Beam 4 Pin behind the Speed Odometer. From The relay, Do I go straight to high beam 4 Pin first then to the on/off switch with a splitter, or vise versa. :|
Hi
I am attaching a general schematic. It assumes that you get power from the OEM connector. If you are powering the lights from the battely through relay, it is similar. Just let me know and I will prepare a new schematic for you
Please note that the position of each cable on the OEM connector is set by memory so, please, double check.
Also, I am not sure if the diode is needed, but definitely it will not do any harm.
1 - 2 of 2 Posts
