1 - 20 of 23 Posts
After reviewing all the heated grip options I have decided to go with the Oxford.
My main reasons are: The Honda grips are way overpriced and don't seem to work real well.
They are fairly easy to install.
The quality seems to be good.
Most important... they get hot !!!
And for $100 how can you go wrong.
Now, which model/size do I need so that I don't have to trim them or trim them the least ????
Thanks, Ti04
I went with the Adventure model. I only had to trim them to the line marked by Oxford on the grips to make them fit well. The left side went on with no issues and fit well almost out of the box. The throttle side needed a little material removal for a nice fit.
Well worth it.
-steve
I too went with the Adventure model and had to trim, i believe the Sport model would work without trimming...
But they work great! I did want the oem for the integration, but price and oem's not working made me switch..
I used the Oxford 120mm Touring model trimmed the lip off the throttle tube no trimming of the grips required.
p { margin-bottom: 0.25cm; line-height: 120%; } Hi!
I‘ve made the same experience as OU812 with my Oxford Touring model.
After using them for some 700 KM I‘ve found heating and handling of the Oxford excellent as well.
Cheers, Gerhard
I have a Oxford touring pair coming this thursday. Would have bought the OEM if they actually worked.
I have the Oxford Touring model and the right one stopped working after about 10 uses. I confirmed the voltage is good. I also did a resistance check and found the defective grip had a very high resistance in the megohm range where as the working grip was 6.5 ohms. Going to try to get warranty on it but a big PIA to swap it out not to mention now with the cooler weather is when I need it.
I have just fitted the Oxford Adventure grips for the same reason, cost, effectiveness. One point to consider when fitting the left side grip, make sure you can pull the clutch lever all the way in. I stupidly just used the arrow marked on the grip and it looked well clear but with the shape of the clutch lever it just caught it! Fixed now.
I’ve got a wiring question about Oxford grips. Mine have been working fine for 3 years. I recently pulled the wires up from under my handle bar intending to re-zip-tie everything a little more neatly. When I took all the electrical tape off I found the red wire coming from the plug b/w the battery and the controller had come loose as well as the Red wire from the left grip plug. Do all the red wires connect together and go to the controller? I cut back the casing that goes back to the controller and there is a little copper joint with 2 reds- I think this is where the power wire pulled out but I’m not sure. Any thoughts? I googled “Oxford grips wiring diagram” and just got pics of the plugs etc...
Update:
All the hots DO go together. Working great again and no blown fuses 👍🏻
I have a 2017 DCT and am considering the Oxford grips based on price and recommendations. Q: are they an easy instal? Plug in behind the dash, wire to the power socket or run wire to the battery?
1 - 20 of 23 Posts
