1 - 7 of 7 Posts
Hi all
I am just about to get an ATAS...
I'm looking for pannier racks that are symmetrical as I normally leave the racks on for extra crash protection. Yet all the ones I've come across so far are asymmetrical. Has anyone come across evenly spaced racks?
Racks
with an exhaust getting in the way on one side of the bike, symmetrical racks aren't feasible. the end result would be that the non-exhaust side rack would need to be moved outwards. and the makers seem keen on making the racks as narrow as possible.
you can have near enough symmetrical panniers, but then you're required to have one smaller than the other.. with a cut-out so it fits 'around' and close to the exhaust. Hepco&Becker Xplorer for example. 40L and 37L
The alternative is to have different size cases, with the exhaust side being narrower. so the width each side is near enough identical. but viewed from the rear looks asymmetrical. for example the Givi outbacks. you can have a 48L on one side and 37L on the other. with just a 2cm difference between the two.
Hi
Thanks for info...
Was hoping for exactly that, that the racks would be pushed out on non exhaust side... seems that non exhaust side rack wouldn't do much crash protection seeing it is so close to body whereas the exhaust side sticks out enough that bike would rest on rack and crash bar instead of other parts. The bumot seems pushed out enough though...
Happy Trails
I thought that the Happy Trails were symmetrical as well as dirtracks.com and Tusk although Tusk still doesn't make a rack for the 2018 and up yet.
I have been searching for a good inexpensive rack and 3 mm thick aluminium box set for quite sometime now and it has been frustrating trying to get what I want. Ideally the Tusk system fits the bill as it also integrates a quick release system but when will it be released for the 18 and up is not known.
Hi
Thanks for info...
SW Motech racks are asymmetrical but leave enough space on the non-exhaust side of the bike for two tool tubes. I've dropped my bike on them with and without luggage. Pretty durable.
Hi
Thanks for info...
I bought the OS32 Kriega soft bags with the SW-Motech Pro Side-Carrier. The rack comes off in about 2 minutes leaving just small parts on the bike (if you wanted to). The Kriega have plates that allow to attache different bags, a rotopax, etc.
My only problem is on the exhaust side the rack touches the exhaust, and its hard to align the holes to install that side. Waiting to hear back from where I bought it from to see whats up with that. Once I have a right side that fits properly, I'll be pretty happy with the setup. I've gone back and forth on the idea of hard vs soft panniers...and for a few reasons, I went with the soft bags: if you drop the bike it absorbs the impact, offroad you are less likely to have your alu boxes break your leg in a fall, you can expand or shrink it a bit depending on the load you carry as opposed to always taking maximum space even when empty.
Price wise, it's not much cheaper than hard cases. Also bought a Sw-motech rear rack so I can install a kriega bag on the top (which also serves as a small back support for my gf).
1 - 7 of 7 Posts
