1 - 16 of 16 Posts
Definitely interested. Are the STR's actually available in the 150/70-18 and the 90/90-21 yet? If so, where?
These look like a great option for AT if you can get them...
This was taken from the Pirelli website with regards to available sizes.
Sizes
SCORPIONRALLY STR will initially be available from January 2017 in the sizes that come on the new Ducati Scrambler, but during the course of the year, the range will be expanded to include more sizes. The complete range of sizes is below:
The rear 150/70-18 is now available in OZ, the front I'm told is still a month or so away. I have fitted the STR Rear and done some 800k 50/50 so far I'm very impressed, just testing the first one out, as I will be doing an outback aussie tour of some 8~10,000 k 50/50 return from Brisbane to Phillip Island for the aussie GP in October let u know how it holds out. (hoping one tire will do the whole trip, as i did do about 4000k on a Pirelli MT90 and only used up about half of it) so I'm hoping the STR will be as good.
Just done the Outex tubeless conversion (no leaks?) and fitted the Pirelli Rally STR’s, hope to get out tomorrow if the balancing weights turn up.
Spooned on a rally str front yesterday to replace oem dunlop. Took it for a 100km run, 20% gravel intentionally riding on the loose gravel in middle and edge of road to see how it tracked, not as stable as an off-road knobbie but pretty good up to 110kph. On the highway quiet and no shakes or shimmies up to 160kph, . Not much mileage to go on but so far it behaves like a street tire on the pavement and seemed pretty stable on loose gravel. If it continues like this I will put on a matching rear when my 1/2 worn Shinko 705 is done.
ps - I also did a tubeless conversion at the same time (3m tape). I will carry a tube in out of the way places just in case the bead comes off if/when I get a flat, but the side wall on the STR is fairly stiff and I had no issues seating the bead (although I used my garage compressor not my portable). Previously did the 3m tubeless conversion on rear rim, 6000km in and no issues)
Site wouldn't let me edit old post for an update, so new post it is.
Around 3500km on front Pirelli Rally STR, about 600km in the dirt. On pavement it still feels like a street tire and off road it is pretty good, you wont mistake it for a full knobby but it is pretty stable in most situations. I havent tried it in any serious mud (and hope not too because I don't think it would end well) but on hard pack, gravel, loose gravel over hard pack, washboard, soft spots to punched out oilfield roads it has been predictable. The only pucker moment so far was a downhill switchback on loose gravel over hard pack (riding on marbles), bike stayed rubber side down so no harm no foul. I haven't calipered the tread wear but it is still in almost new condition, unless it starts scalloping it is just getting scrubbed in.
Still burning off the Shinko 705 on the rear which has been a good wearing predictable tire (around 9k km and probably still a good 3k left). It is more than adequate as a rear on gravel roads and trails. The 705 will be done after my trip to southern BC at end of July with buddies on cruisers (all pavement) at which time I will spoon a STR onto the rear and give it a whirl 'cuz I like the front.
ps: 3M tubeless conversion front and rear still holding air without issues
Thanks for the update and good to hear. Having Scorpion rally STR's put on this Thursday, on the new rims that Honda gave me (and on which I have now done the 3M tape and sealant conversion too). Looking forward to getting off the paved sections a bit more with these tires, have only heard good things about them, with some saying they equal the Conti TA2/3 on the road.
I had them on my Scrambler 1200XE and they are ok, but I probably wouldnt buy another set. The front wore very unevenly, the rear wore pretty fast and even new they look like they have 2000km on them. If I want a more road oriented tire I'll go to Avon for Trail Riders, when I plan on doing more dirt, Shinko 804/805 has been my tire of choice for years and have never disappointed me (and they are insanely cheap on top of providing excellent performance at pretty much everything you throw at it).
I have had a set of STR's for a while and they are pretty good. They are better on paved roads than off but do give reasonable traction on dirt roads. They feel very soft in the side walls and I don;t think they would be very robust if the ground was rocky. I am not so sure about carrying a load with them either. I have swapped them out for some Motoz RallZ's for our upcoming outback ride as I know they are solid and puncture resistant.
I put on both front and rear tires to replace the OEM tires in preparation for a cross country trip from Northeast Ohio to Big Bear Lake California. I planned on a lot of off road treks on the way through Colorado, Utah and Nevada; even more around Big Bear on fire trails, single track, and down the mountain in the Mojave desert. But a family emergency in Oz nixed that double quick, so off to Oz I had to go. The following comments are pertaining to street and freeway use after I got back. They hum above 30 mph. Very noticeable at freeway speeds. That said I only notice it when not wearing earplugs; I usually do when riding. Considering they are designed for more off road use they handle amazingly well on road. In fact, I find it easier to roll the AF over into a curve or around a corner than the OEM Dunlops. Do they stick? Oh yeah, I’m virtually on the pegs and it’s like being on rails, now this is when it’s dry so I can’t comment on wet handling yet. Hopefully soon I can add my two cents regarding off road capabilities.
I use Pirelli Scorpion Trail 2's which are very good for tarmac riding, and give plenty of confidence when cornering, wet or dry.
Interested in the STR when I need new tyres, but wondering how they would compare to the Scorpions for tarmac riding?
I only have the STR in front (combined with 705 in back). My impression is the STR is about as aggressive as you can get without a real penalty.
It's fine on high speed sweepers and low speed tight turns, though I'll guarantee the Trails were better.
I don't have a steering damper, but after installing the STR in front, the thought has crossed my mind. For example in curves on grooved motorway. It doesn't follow the grooves way some scooter tires might, but you will notice some interaction between the "knobs" and grooves.
1 - 16 of 16 Posts
