Ok, so for the next farkle to my baby, is a central hub that I can power accessories and lights from, and a 12V socket for charging my nav unit!
I am using 14 Gauge wire and weatherproof heat shrink connectors. I found this fuse box at a local auto store that I can run a main lead to from the battery then smaller leads to the accessories and lights from there. Each slot accepts it's own fuse as well like a normal car fuse box. I plan to mount it up in this space under the snorkel for the airbox on the exhaust side.
I ran out of time and will finish this install this evening! :nerd:
P.S. Do you guys think I should go a bit larger than 14 gauge with the lead from the battery? I figured my accessories and LED won't draw that many amps, but what are your thoughts? last thing I need is for my bike to light up the wrong way! hahahaha
