1 - 1 of 1 Posts
It can turn itself off under a few conditions.
It happened to me last week on a gravel road, apparently because the road was bumpy, the ABS (front and rear) shutoff and I found myself with a front tire skidding towards a ditch. The ABS light was flashing on the dash, which means it was disabled.
I called Honda, they said take it to a dealer and this is what they said:
DTC: 4-1
Function Failure: Front wheel lock • Riding condition
Symptom/Fail-safe Function: • Stops ABS operation
So, as I thought, my front wheel did lock up going into the turn which caused me to slide off the road. The dealer said it appears the entire (front/rear) ABS will shut off under certain conditions, one of those being if you're riding on a gravel road and the front wheel locks up. Seems a bit nonsensical, but there it is.
Apparently, the entire ABS can auto-disable in certain non pavement situations. Something to be aware of.
1 - 1 of 1 Posts
