1 - 3 of 3 Posts
I sent Touratech a question about this issue and got no response, so I will ask here.
I recently bought a lightly used Touratech front seat. The seat latches perfectly into the high position, better than the OEM seat actually, but will not latch into the low position. Seems like something is not letting it drop down far enough for the latch to catch or the top hook on the front of the seat is too thick to fit into the slot on the tank.
Just wondering if anyone has had this issue and if so what was done to correct it.
Hi swimmer
Did you have any trouble with the OEM seat in the low position?
This was a problem for me (and many others) until some kind people on here helped me resolve the problem
Discussion Starter #3
Hi swimmer
The OEM seat is a bit difficult to get into the low position thought that seemed to be caused (not positive) from interference with the rear seat. With the Touratech seat I have tried fitting it in the low position with rear seat removed and it makes no difference, it just won't go low enough to latch.
1 - 3 of 3 Posts
