Ready to rumble... Just need a Remus Okami and the job is done.>
Looks tops mate.Ready to rumble... Just need a Remus Okami and the job is done.>![]()
Hepco Becker... pretty good piece of kit. Have to removed the whole exhaust to get to the frame where rear bolts onto frame though but was not so hard a job.Looks great, thanks for the post. What brand are the engine protection bars? they fit well with the B&B Safari plate
Those are Barrett racks, bolts on under saddle, at foot rest and the bar that goes under mudguard bolts to the frame under the seat with 2 bolts. Then the bar at the back via the number plate is just a compression bar. Its pretty sturdy, certainly as strong as the engine guards so there is good protection from a fair to middling fall over.... With soft bags you'll definitely pick it up, have a laugh and carry on none the worse for wear.... I added the Barkbusters for insurance. If the handle bar bites the dirt the OE soft covers give no protection for the brake/clutch lever.What rack too? Looks like it has the WolfMan loops.
Aaah... that tube is good old storm water pipe 90mm and screw cap fittings. It is cut down to size now so it doesn't stick out. Has proper clips to attach to the rack. Every DR you see has one for tools... It seals so you can also use it for water. I got 430 mm under there so it's about 1.5 litres vol. Cost me about 20 bucks to make with the help of my-favorite-place-in-the-world Bunnings!:grin2:What do you keep in the long tube?
ThanksAaah... that tube is good old storm water pipe 90mm and screw cap fittings. It is cut down to size now so it doesn't stick out. Has proper clips to attach to the rack. Every DR you see has one for tools... It seals so you can also use it for water. I got 430 mm under there so it's about 1.5 litres vol. Cost me about 20 bucks to make with the help of my-favorite-place-in-the-world Bunnings!:grin2:
