Standard or Adventure Sport? They are different with regards the side panels. If the standard then you should be able to find the instructions for fitting the rear rack which shows most of it.
Do you happen to have a link/pdf /source for that manual? I've seen a couple listed here on the forum. Suppose I should just go ahead and get my own.
It is easy, just need firm but not excessive force. If it feels stuck there will be a clip or bolt you have not removed.One thing is for sure … As with any disassembly on the AT, it won’t be easy…
I have the paper one but got the pdf one from a Russian site but don't recall where, sorry.Do you happen to have a link/pdf /source for that manual? I've seen a couple listed here on the forum. Suppose I should just go ahead and get my own.
