1 - 6 of 6 Posts
Hi all. I purchased a used set of SM-Pro (Rugged Roads) rims for the AT. I wanted to replace the studs and bolts on the rear drive hub fo my installation. I had an incident today where one stud backed out and seriously scored by swingarm. I can't believe it backed out, yet you can see loctite (blue) on the threads. I looked through the shop manual and can't seem to find torque values for those rear studs. I've tried contacting RR and SM Pro.
Studs are 90102-MAS-000 12x25 the only reference I’ve seen is the spec for a same size bolt in the shop manual, they sell the studs but torque values seem to be a state secret.
54633
Yes, I agree. Can't find those specs anywhere. Long side of studs into hub so sprocket sits on unthreaded shoulder. Nuts are 100nm but I cannot find stud specs anywhere. E-mailed RR and SM-Pro, who make the hubs. :unsure:
If a torque value for a specific nut/bolt is not given in the shop manual then it should be tightened to the torque specified in the standard torque values table, usually located in the first chapter.
1 - 6 of 6 Posts
