Sounds about right, I get a preload setting of 10 clicks from the zero position solo and 27 clicks with pillion to get approx 75mm. under sprung for us really but its ok for now.Has anyone else measured and set the rear suspension sag?
I weigh about 85Kg in my riding kit. The AT has approximately 220mm of rear wheel travel and I believe the sag should be about 1/3 which is approximately 73mm.
The handbook recommends 7 clicks of pre-load. Starting at 7 clicks I started to increase the pre-load to get 73mm sag. I ended up with it set at 28 clicks.
Anyone else fancy trying this and then pointing out my mistake?
The pre-load knob is quite small and tucked away so not the easiest to adjust.
Just digging around to see what people are doing in terms of suspension setting.Sounds about right, I get a preload setting of 10 clicks from the zero position solo and 27 clicks with pillion to get approx 75mm. under sprung for us really but its ok for now.Has anyone else measured and set the rear suspension sag?
Yes I do think the pre-load knob is small compared with some, I wouldn't say it is easy to use, especially when you want to increase it by 20 clicks. I am aware of the rebound and compression adjusting screws, compression near the top and rebound at the bottom.Also, xsilvergs, the pre-load knob is on the left side with a big turn wheel, you said the pre-load knob is small and tucked away
Just curious - what would you set it up for 102Kg?from Standard settings
Preload :-
Rear +15 clicks
Front + 1 revolution
Front rebound Screw
+1 revolution
feels much better to me so far at 95Kg
Adding to this, yep I'm in trouble. I took a ride up the Wicklow Gap this weekend with my daughter. The handling got pretty poor with the extra weight, not wanting to turn in well, I know the rear was sitting down far to low. I adjusted the front pre-load two turns off max which gave me a slight improvement but still not great. I think I am going to have to back off the front preload significantly when two up and live with a greater sag front/back than usual just to get the bike geometry right. Probably not a huge problem for road only use but given the Honda maximum weight rating for rider, pillion and luggage is 195Kg that is a pretty poor show. If I can't get a decent front/rear sag at 120Kg where is Honda getting the 195kg rating from? Maybe just the rear sub frame loading and nothing to do with the suspension?OK, here's one for the more "portly" of us. I am 6ft and 120Kg (260lbs) in full gear. When I first rode the bike with stock settings it was woeful, pulled over on the side of the road and added 7 clicks on the rear pre-load, big difference.
After a few hundred km I wasn't happy at low speed, it felt like I had square tyres. It looked like "amateur hour learner motorcycling" at slow speeds when cornering around town. I felt a complete tool!
Given full travel is listed as 221mm (8.7") rear and 231mm (9.1") front my goal was to achieve 66mm rear sag and 69mm front.
I had to go all the way. The front was fully in 15 turns but I achieved the 69mm sag. Rear was fully in 35 clicks (no click on the front adjustment) but I could only achieve 85mm rather than the desired 66mm.
This might at least give you an idea what 120kg does for the bike. For me taking the time to do this has transformed the bike, handling is considerably improved, I am relieved that the bike is now 100% useable, high speed and low speed (even with 85mm rear sag).
So I cant say the rear is too soft because I am 120kg! I will never go off-road on this bike (why would you, the weight!) my little air-cooled DR350 would be more enjoyable.
If I ever two up, long distance tour with luggage I suspect I may be in trouble at the rear, but for now it will suffice.
Well the good news is that from the picture it looks as though your daughter enjoyed the ride regardless of the suspension.Adding to this, yep I'm in trouble. I took a ride up the Wicklow Gap this weekend with my daughter.
Hi Guys,
Looking at setting up the sag on my bike this weekend. What sag value are you aiming for front and back, 38%? It's a manual model, mostly offroad riding and with 20kgs of luggage and a 90kg rider.
Thanks.
