Thanks EmmF. Any chance you have the SBS part numbers?Hello, Anyone changed brake pads on front or rear and what brand of non OEM pads were used? Thanks.
Sorry the EBC part numbers😁Thanks EmmF. Any chance you have the SBS part numbers?
Thanks EmmEffFA174HH
I use Honda OE pads.. 45,000km and still life left on the 2nd set.Hello, Anyone changed brake pads on front or rear and what brand of non OEM pads were used? Thanks.
How long did you do with your first OEM rear pad? Mine is about done in about 5000km, meaning I get about 17000km on the first rear pad. If you get this much km's on the rear pad, I almost start second guessing the quality of the rear pad I got from factory.I use Honda OE pads.. 45,000km and still life left on the 2nd set.
Swapped out the rear at ~25Kkm. I use the rear a lot in slow speed stuff and to stabilize the bike when braking on the road, but most of my braking force is always the front brakes either on the road or on gravel.How long did you do with your first OEM rear pad? Mine is about done in about 5000km, meaning I get about 17000km on the first rear pad. If you get this much km's on the rear pad, I almost start second guessing the quality of the rear pad I got from factory.
