Hi, there are no splines to adjust on the bottom. The gear lever just rotates on a smooth shaft.
So if you can't get enough adjustment by loosening the lock nuts and twisting the linkage bar, which moves the gear lever up or down, then just remove the top clamp (where the shaft comes out of the engine case) and refit on the next spline.
Gar.
