Hello everyone,
I have a 2017 CRF1000L Africa Twin manual and I have been having an issue with it after an incident with a tire shop. A couple of months ago I took my wheels in to have the tires replaced with new stock tires and I figured id get my bearings replaced while I had the wheels in. I brought the rear tire with the sprocket and all due to a bearing being located within the sprocket chamber of the wheel. I had not noticed that the shop had lost a spacer that goes in the hub assembly behind the sprocket and being a relatively new AT owner this was the first time I ever dealt with my wheels. The shop said nothing except that the work was done and all bearings were replaced and I excitedly got home and installed my wheels and decided to test out how the new tires felt. I rode the bike for maybe 15 min total, I was getting the feeling that something was wrong and immediately tried turning around and getting home. Luckily I almost made it to my street when something gave and after removing everything I figured out that the rear bearings had failed and broken. After inspection and researching I figured out that the sprocket hub spacer was missing and missing it caused the bearing failure. I called the shop and they couldn't find my spacer and also refused to be responsible for losing it or for the brand new ruined bearings. After getting the bearings replaced elsewhere and waiting 2 weeks for a replacement spacer to arrive in the mail I was excited to finally being able to enjoy my bike but that was too much to ask. Now, whenever I ride my bike I believe the ABS is not functioning anymore after tons of research and troubleshooting I cannot figure out the problem. I thought my rear speed sensor was ruined after the incident so I purchased a replacement 2017 rear sensor off of eBay and swapped it to no avail. I have tried reading the codes to the bike which were pointing to the speed sensor but I am lost and just want to ride my bike as the weather has been great for riding. At this point, it could be a number of things from bent speed ring to improper speed sensor gap. My question to this wonderful community is if anyone knows of a good shop that won't charge me an arm and a leg to fix my bike's ABS. I live in Aurora, Colorado and due to COVID, I don't have tons of money to throw into repairing the bike. Any helpful suggestions are appreciated but please don't criticize me as I am a young independent man. Sometimes the only way to learn is to struggle yourself and learn from the experience. Also, would it hurt to ride my bike with the ABS malfunctioning? I had read that it reverts to traditional braking if there is an issue with the ABS system. When i try and ride the traction control light turns off after 6mph but the ABS light continues to light up and after riding for a bit begins to flash.
Thank you everyone,
-JT
Thank you everyone,
-JT
