So, during disassembly for a valve clearance check. The coil tray has to be removed. In the process two coil wires pull out. Odd look ends I observe. Where's the cavity were the cap's brass screw would thread into the end of the wire? Strange. Surely this isn't the connection. Cut away the boot cover and see what you see in the picture. No brass screw. So, I dig into the wire looking for a screw. Sure enough, they are there. Then, I see they have been broken for a while as evidenced by the signs of arcing (black soot at the break). See for yourself. Anyone else?
My AT is at 19k miles. At this point I've ordered four new plug caps. Probably will use a dielectric grease during reassembly. Then, ordering new spark plug caps to replace at the next valve clearance check as it just became a part of the routine maintenance.
