1 - 7 of 7 Posts
Those R&G ones look well made, but I'm looking for something that allows you to remove the rear wheel as well.
I haven't seen any RG ones that allow the axle to be removed.
I am aware of the scoops and I even have them, but they are not nearly as stable and easy to use.
It's been a few years since this post was made - has anyone found a good rear swingarm bobbin solution?
The R&G part doesn't seem to achieve anything, simply moving the lift point from the axle to behind the axle... but you still can't remove the axle. The CNC milled aluminum parts from bikefarmmv look like a good solution, but I was hoping someone else has tried them before I go through the effort of getting them from Germany.
1 - 7 of 7 Posts
