1 - 14 of 14 Posts
Hello everyone!
I want to make the bike have shorter gearing. Right now 2nd will go above 60 and I have really no reason to ever shift into 6th without breaking a federal law. I would like 1st 2nd and 3rd especially to be more usable at slow speed for technical riding. Does anyone have experience or recommendations on what kind of gearing i should look into? Change the front, the back, or both? I googled some stuff but I would love to hear firsthand from someone who has done it.
Thanks in advance!
Well usually the easiest and cheapest way is to go down 1 tooth on the counter sprocket if it is available anywhere.
Easiest as mentioned is to go down a tooth on front, won't (shouldn't ) need to change the chain then. They are available, there was a post on the AT thread on adv rider which gave the part number. JT sprockets do it but I can't remember the comparative Honda model.
I have a 45t rear on mine with OEM chain fitted, granted it has 17,000 miles on it and has probably stretched but it went on no problem:wink2:
I had under 1000 miles when I went with a 44, and there was no way a 45 was going to make it for me...SC
CRF1000L | Gold Wing DCT
Bummer, looks like I'll be buying another chain to fit a 45t. That is unless I convince myself to just go with a 15t up front.
2016 Honda CRF 1000L Manual
Hello everyone!
Thanks in advance!
Go two teeth higher on the rear wheel sprocket: 44 vs. 42 teeth. This supplies a decent (4.77%) increase in available torque with a corresponding effect on the speedo and odo readings.
Reactions: WeeWilly
1 - 14 of 14 Posts
