standard factory suspension settings- 2017 manual
708 views 2 replies 2 participants last post by  Trek Moto
#1 ·
I want to soften my bike up for square edge hits,, I have stiffer cogent suspension front and rear.. I want to go back to default since I have piddled with it.. I think the compression on the front is full in, 8 clicks out for factory settings, with about 12 clicks total, so Id have about 4 more to play with, what about the rear? compression is the one at the top of the shock, correct? So I want to soften it up, what is the factory setting for the rear compression? I want to start from scratch and go from there, Thanks!
#3 ·
For future reference by others that come across this thread, my Honda service manual for my 2017 CRF1000A specifies the following:
Forks
Pre-load: 5 turns from full soft [in other words, 5 turns closed from full open*]
Rebound: 2 1/4 turns from maximum position [in other words, 2 1/4 turns open from fully closed**]
Compression: 8 clicks from maximum position [in other words, 8 clicks open from fully closed**]
Shock
Pre-load: 7 clicks from maximum position (first click is "0" position) [in other words, 7 clicks open from fully closed**]
Rebound: 11 clicks from maximum position [in other words, 2 1/4 turns open from fully closed**]
Compression: 14 clicks from maximum position [in other words, 8 clicks open from fully closed**]
* to get to fully open turn counter-clockwise (anti-clockwise) until you reach the stop
** to get to fully closed turn clockwise until you reach the stop
