1 - 11 of 11 Posts
Finally bit the bullet and returned to my go to suspension people at MPE to upgrade the boingers on the 2019 ATAS as they have done on most of my previous steeds. Mostly heavier springs, mid valvinng etc for my weight. Great small business to deal with, principal Paul and his crew down to earth, honest with consistent workmanship.
Went for quick offroad ride locally, and night/day improvement. Suspension work is one of the best upgrades one can do to their bike, particularly if you're 20-30kg over the target weighted rider. Drive, braking, lofting all improved, bike sits noticeably taller too 馃槄.
Also fitted a 44T rear sprocket replacing standard 42T, another great improvement I believe, almost suggest 44T should have been standard issue. 2nd-5th all more flexible offroad, revs still OK on tarmac. 44T will fit with standard chain, just swapped sprocket to trial, will replace all gearing when chain requires it.
Good pick up @fastfreddie , even though I never heard any noises on ride you still made me go and check the sled under the house, but alls good! 馃槄
Motoz Tractionator Adventure tyres, 70%dirt. 馃憤
Sorry about that, I couldn't figure it out for sure and figured better safe than sorry.
Your bike definitely looks the 70% dirt part. I like it.
Suspension, tires and gearing are my main points of focus, as well, on pretty much every one of my bikes. Brakes get upgrade as soon as the OEMs prove disappointing.
Now if I could just get an AT into the stable... :(
Best of luck with 'housing' an AT, worth the effort IMHO. Short of a catastrophic failure, mine will be a long termer.
Looks and sounds good!!! Looking forward to some ride reports about where that new suspension gets you.
Reactions: Rscar73
HI Rscar73, absolutely gorgeous looking bike. Very nicely done mods.
Reactions: Rscar73
2016 Honda CRF 1000L Manual
Both mods are well worth the time & cost to roll onto the AT. Especially if you're a heavier rider. Ol' Red is sporting 脰hlins front and back as well as a 44-tooth rear sprocket. The only down side is the speedo and odo run high by about 4.7% but easily manageable.
Reactions: Rscar73
Discussion Starter · #10 ·
Ohlins is next level 馃憤. Re odo error, I do oil/filter every 6K depending on riding done between, so I can do every 6.3K now...馃槈, which is within my +/-10% tolerance anyway 馃槤
1 - 11 of 11 Posts
