41 - 60 of 110 Posts
Managed to get out around North Wales on monday to test out Swens up draught eliminator ,
260 miles in most conditions, never thought it would make such a difference, all those problems with helmet buffeting , I thought it was the screen, just shows how wrong you can be, I didn't go out in the Schuberth E1, I'll do that test next time out,
But well worth the money and must be one of my best mods along with the Batzen adjustable screen , all I need now Swen is one for my MV Turismo, please !
I see that you are using both types of wind management devices (Batzen & Swen deflector) do you feel that one made more of a difference over the other? I am guessing that both are the way to go.
Thanks in advance.
Or you could just take the peak off your helmet for street/high speed riding like every other motorcyclist, a problem of your own creation! Try continuous lifesavers with a peaked helmet at high speed, that will soon piss you right off.
Managed a 200 mile jaunt into the Welsh mountains yesterday avoiding most of the snow, Testing the Schuberth E1 with the peak left on, It's certainly much better with Swens up draught eliminator on, my spectacles don't vibrate anymore, But the flimsy peak still vibrates enough to annoy me, The peak certainly helps in the low sun at this time of the year, one of the main reasons I bought the E1,It's also easily removed when needed, and a better buy than the C3 IMHO, with better ventilation,
I've now done 12,950 miles miles on my AT, DCT, and not yet been on a motorway, the original tyres were replaced at just under 6,000 miles and replaced with Conti TA 2s, I now have a set of Alpina wheels fitted with another set of Conti tyres, I also fitted Dyna Beads for balancing the wheels, rather than the un sightly stick on weights, these have been on for the last 2,500 miles, I also changed the chain and sprockets with the new wheels, and went for a super sprox rear (think thats what they're called) from Rugged Roads, and yesterday I put a set of stainless Steel sprocket nuts on , to replace the corroded Honda ones,
Mcrir, Yes , both are the way to go, with the Batzen you can drop it to the low setting for hot summer days, or the high setting for winter, I tended to stop a few times on a run at first, to find the right spot for the screen, it now stays in the same position most of the time, I also had the one with the SAT NAV mount, and find it first class, Cheers, Graham
Discussion Starter #50
The last weeks I was super busy with my work, but now I have more time to be online again.
..... If you are running a stock screen, this may be the best $39 you spend on your AT. It is a very well thought out and delivered kit, top notch quality and construction backed by great customer service.
Ride Safe!
Rob,
thank you so much for this amazing review :) Normally I would say that you made my day.... but I was smiling for a whole week :grin2: !!!
Elvisto, I am happy to hear that the SWEGOTECH Forkshield makes such a big difference.
Seems like a good solution. Can the steering still be locked when fitted ?
Yes the Forkshieled allows full lock steering. You can see this at the end of the installation video at around 2:40min:
I was skeptical of this but the price was better than anything that mounts on the windshield, so I figured I'd give it a shot. I had previously just removed the peak from my helmet, but there were still some vibrations and buffeting. When this thing showed up I thought I had just gotten ripped off, it's so simple I was sure there was no way it could make any difference. I have to admit that I was wrong.
I noticed the difference immediately, but I reserved my judgement until I had a chance to open it up on a long stretch of road. The thing this does is simply clean the air up behind the shield. What I mean by that is, before I had to stand up to be in clean air. Once I was in it, the helmet reacted predictably, but without the vibrations or buffeting. After installing this, I noticed that the clean air was simply right at the transition over my head now. I can literally lift my chin and feel my visor scooping the air flowing over my head now, but there is still no buffeting or vibrations. It's pretty amazing to me, you really have to experince it to understand what a difference it makes. I know I sound like an infomercial, but I really just wanted to share that this was a cheap and effective solution to the main problem with aero that I was experiencing. Just make sure you know what you're getting. This does not eliminate the effect of crosswinds, or the disturbed air behind other vehicles. It simply eliminates the problem of dirty air that the bike itself creates behind the screen and makes the transition over the top of the windscreen where it reaches the rider smooth.
In short, if you are having issues with helmet vibrations, I highly recommend that you try this before anything else. I installed this with no other modifications to the stock screen and feel that I will not need anything else regarding this issue.
Fitted mine yesterday,
Took a while to get over the final cost once I paid the packaging and the £17.40 import duty.....
Took it about 50 miles today and found no perceptible differences. Bit upset.
Z
I just ordered one for my 2017 DCT Red, White, Blue coming 1st week of April. I'll have this part before I have the bike! Thank you!
Discussion Starter #58
I am very happy to hear this. Thank you for this detailed review
BTW, I had a good laugh about the "infomercial"... your check is in the mail now lol
I bought one. It works. Looks clean.
Happy to hear that you like it. Thank you so much.
Z
I am sorry to hear that you didn't feel an improvement on your bike. This is not typical, most Africa Twin riders love the Forkshield and notice directly a big difference on their ADV helmet. So may I ask how tall you are and what helmet do you use? Also one more thing. Like Danwray wrote in his review above, the Forkshield can't reduce any crosswinds. So on a very windy day it is often harder to notice the improvement, because the wind from the side can still shake the helmet.
Already ordered mine...
Great idea, well developed!!!
Thank you
if you ship them to europe will there be extra costs like customs clearance?
Thank you for your request. If you order it just using my Paypal-Link, then unfortunately there will be extra costs like custom clearance or taxes for most countries once the item arrive. These costs varies depending on your country. I think for Germany it is about 13-14 Euro if I remember this right. I lived just 10Km from the Netherlands boarder and know that in general taxes and fees are higher there than in Germany for example. So I would assume that the fees would be maybe around 16-18Euro.
Therfore even if I have to pay the Ebay fees I highly recommend every non-US customer to order via Ebay:
http://www.ebay.com/itm/Forkshield-updraft-deflector-Honda-Africa-twin-1000L-reduce-helmet-vibratation-/112268148310
eBay uses a "Global Shipping Program". We just sent the item with priority mail (fast & secure) to a eBay Hub in Kentucky. From there eBay forwards it to everywhere around the globe. Therefore they usually also get better shipping rates. AND eBay also already takes care of the customs. During checkout they directly charge you not only for shipping, but also for every country specific import charges. This way it is "out of the way" and you don't need to take care of this later when the package arrives in your country. And since with eBay the custom are already cleared, they deliver it to your door. Otherwise the package can get stuck at customs for clearance and you have maybe to wait longer.
Thank you and congrats on your new bike. You will love it !!!
Had no issues with helmet vibrations until installing the OEM low seat, which seemed to lower my head into an unstable pocket of air. The buffeting was intense enough to blur vision and induce headache after a short period at highway speed. Thought I would have to ditch the low seat or look for an expensive windshield solution. After reading this thread, I ordered the deflector on eBay, and installed with ease only a few days later.
After a 300km road trip, happy to report the buffeting is gone! Such a simple solution for a major improvement in comfort.
