Hi, could someone direct me to a switched live wire somewhere under the seat that I could pick up a trigger wire for my Aux fuse box please, the bike is a European 2018 ATAS and there appears to be some unused connectors under the seat. Anyone know what colour wire is switched live ? Thanks in advance, John.
Posted not long ago a copy of wiring harness scheme.
Reactions: Kirky1298
Under the passenger seat you'll find a 6 pins Sumitomo MT090 connector. Green wire is VE-, switched live should be Red/Yellow wire and permanent VE+ should be Red/White wire. A simple test with a multimeter will confirm you if I remember correctly! :wink2:
