1 - 3 of 3 Posts
On my way in to work this morning my thermometer on my the dash disappeared. Completely gone. Is ther a troubleshooting technique for this? 2017 AT.
I have not heard of this issue before. I am assuming a restart did not resolve the problem? If not failed sensor or wiring between the sensor and dash possibly?
Let us know the result when you find it.
Sent from my SM-G998U1 using Tapatalk
Pretty sure this is the sensor, with the white dot, as viewed looking past the lower right of the dash.
64166
If it passes a visual inspection, this is what the service manual recommends.
64167
64168
If you are not so technically minded, take a look for obvious damage. Disconnect the plug and look for damage or corrosion. Put the plug back on, cross your fingers and see how it went.
Good luck.
1 - 3 of 3 Posts
