Seems like a good spot for a RAM/Garmin ball mount...
I was actually asked by someone to make something similar a while back but with some sort of star/serration config. That part was not the problem but the clamp was to be all rounded in profile which would have taken a long time to mill for me as I don't have the spindle speed on my mill (it is old ) and thus uneconomical.Seems like a good spot for a RAM/Garmin ball mount...
It is supposed to add stiffness to the bars, whether that is a good or bad thing I don't know.Hi Hood,
What is the purpose of a bridged clamp?
No deposit require, better wait and see if I can make it firstHood I would be up for one of these. Not sure if it would benefit my riding but it’s a one off 👍 happy to paypal you a deposit etc
Riser/top plate wouldn't really be an option as the holes are too close and thus the bolt heads wouldn't fit. I suppose it could be done by using socket cap screws and recessing part of the round that fits into the bikes own risers but it would look crap I think as the cap screws would only be partially recessed.You know better, machining is all Spanish to me...also (if possible) why not make a "Top plate / Riser plate" like one product that can be used as a Plate or Riser, for more versatility ?
As far as Logo, maybe reduce the size a bit, or even better change the lettering to "HOOD" (why not) and that way you can drill the two RAM ball mounts inside the "OO" for symmetry.
That way you won't be spending the rest of your life in prision for "Logo copyright infringement"![]()
Hood needs to start a small business.......Dado do they make this for AT? Pretty cool looking mountHood, just a suggestion if you don't mind...if you do make these plates, it would be beneficial to include/ install a couple of these RAM ball mounts, like I had on my FJR-1300ES MV Vernolen riser plate
A few options of RAM ball, you are a bad man @Dado
Diamond mount RAM ball, probably best option due to thickness of the bridge.
Without logo
With logo
Not sure on dimensions of normal RAM ball but should be close.
A few options of RAM ball, you are a bad man [B]@Dado[/B]
The Vernolen mount is FJR specific, not sure if AT needs something as elaborate...FJR handlebars are two parts with ability to adjust the Horizontal axis angle.Hood needs to start a small business.......Dado do they make this for AT? Pretty cool looking mount
This oneA few options of RAM ball, you are a bad man @Dado
Without logo
With logo
