1 - 1 of 1 Posts
Inside.. 2 more big boxes.
Front wheel.
Rear wheel.
and here.. a view of the inside of the rim.
Black everything as you can see.
BRAKES
The Kineo hub and bespoke brake disc carrier system (one or two for the front wheel and a single carrier for the rear) enables straightforward installation the original stock/OE (or OE compatible aftermarket) brake discs with no modifications required and ABS sensors are also installed as originally designed. Brake disc carrier components are supplied in a Black anodised finish.
Basically, you swap over your existing Brake Discs and ABS rings from your existing wheels onto your new Kineo Wheels.
CUSH DRIVE & SPROCKET CARRIER
Kineo wheels are supplied with a specific 8-pin Cush Drive which is completely external to the rear wheel hub. This feature is entirely independent of the wheel and has its own a double-row bearing to support the radial load induced by the chain to supplement the wheel's two integral bearings. Cush Drive and Sprocket Carrier components are supplied in a Black anodised finish.
Unfortunately their arrival comes just before a week away.. so, I wont be getting them fitted until my return. First week in March all being well.
1 - 1 of 1 Posts
