1 - 2 of 2 Posts
Today I installed Touratech rear rack and hard cases. The only issue I had with my rear rack was that after you drill two holes in your rear fender, you have to thread two new bolts back through the Honda frame. My AT had on issue with one of the threads on the bolt hole. This was Honda's issue not Touratech's. I had to re-thread the bolt hole to get it to properly thread in. I also could not get the bushing type washer to re-seat correctly after the install so I just used a fender washer of the same size. It added an extra hour to my install but it looks and works great now. I hope none of you run into the same problem.
1 - 2 of 2 Posts
