Both wheelie and traction control will interfere, however you can get pretty far with TC and W on 1. That said tires and surface will obviously play a big role, I've ridden offroad in the mud with TC on 3 and it's fine until it's not. When it's no longer fine you will see RPM drop to 1000 and the bike will do nothing, or worse, get stuck inevitably.
The bigger problem is ABS coming back on, especially when descending or in less than ideal conditions. Keep in mind that everything resets to ON after restarting. You can use the killswitch instead of ignition for shorter breaks, sadly tipover sensor requires a full restart of the bike.
