1 - 3 of 3 Posts
Hi all,
Had my ATAS for a few months and looking to set tubeless tires Karoo Street, assume the rim of this bike is OK with that idea (MT type) and i can use them with the tube? Scratching a little my head as first time i am setting a mix tire so i can head out on some green lanes (dry ones..). Thanks for the help!
Hi,
I just went tubeless. I used the outex kit. I somehow f-up the rear, and had a leak on my first ride. I fixed it with flex seal tape from home depot. will pull it apart in the fall to see how it held up.
good luck. the outex is not easy to apply if you are like me noob-mechanic.
Hi,
Hey, at least you gave it a go @TwinWin and still around to brag about it. That takes some guts. (y)
1 - 3 of 3 Posts
