1 - 6 of 6 Posts
Hi all,
does anybody knows if it is possible to upgrade AT model year 2017 with trottle by wire and large gasoline tank same as AT adventure sport 2018
Last time I checked the stock gas tank was about $1800 CAD. A throttle by wire conversion would probably be just as much $$. The cable throttle doesn't seem so bad if you've ever ridden bikes with bad (delayed response) throttle by wire systems. More effective route would be to get a kaoko throttle lock for cruise and a camel tank which mounts on the rear for better weight distribution.
I think the wire loom will be complete different. The PGM-FI (ECU) will be complete different to. So ECU only is already 3500 €.
Thanks to both of you. Upgrade would be too expensive.
Do you have any link where I can buy camel tank which mounts on the rear?
Hi Vojko,
At one time I was wondering if I should change. Once I saw what the seat height was going to be I decided not to make the change. Instead I fitted a Camel Tank, 6.5L and I did the Hyperpro suspension upgrade. Its a totally different bike now.
1 - 6 of 6 Posts
